<- **first bike help** grinding noise..please help
Old Oct 26, 2008 | 04:26 PM
Macaco's Avatar
Default <- **first bike help** grinding noise..please help
i recently bought a 99 f4 with 44,000 miles for dirt cheap i thought ($1500), bike looked in good shape and rides great; but recently i noticed two things and I think it might be the same problem.
1st - When the bike is in neutral, and the clutch is released i can somewhat hear (faint) and feel (faint) a grinding noise (similar to when a car is out of coolant and the fan is trying to run); but when I run the bike it all goes away, or if im in first gear with the clutch pressed and stationary, no noise is heard and nothing is felt.
2nd, the other day I was riding with a bunch of guys who know bikes, and somebody riding abreast to me said they might've heard a wheezing noise usually heard when I take off (maybe first gear or neutral)
Question being, transmissions or gears (chain set) if needed, is it SUPER expensive or cheap enough to keep the bike around?? I'm not totally mechanically challenged, I know my way around cars and don't initially see motorcycles being that different. Any suggestions to what I can do to pinpoint the problem so I can fix it??
THANKS!!
Old Oct 26, 2008 | 06:43 PM
pacemaker's Avatar
Default RE: <- **first bike help** grinding noise..please help
1st off, the Clutch baskets on Honda's are loud, noise goes away when you pull the clutch in.
2nd, the other noise could be your chain, never heard of a 'wheezing' noise, except for a radiator going south. Does your bike feel ok when changing gears etc? gear box troubles are that, you know when their happening.
Old Oct 26, 2008 | 08:12 PM
six00RR's Avatar
i got an cbr 600rr and somtimes when u press the clutch in it makes a little clicking kinda noise..its just a noisey down side to honda bikes i guess..or it could be somthing to do with ur clutch cable or somthing..im not to for sure tho
and that weezing/rasping sound..i am currently havin the same problem.im not sure if were havin the same issue but when i start off and ride around 0-5000rpms it makes a rasping noise..and iw as told this is the chain tensionor and that they are generally bad on honda bikes...i was told go with a manual one..not sure if these are theproblems ur having but sounds somewhat close..hope this helps
Old Oct 26, 2008 | 08:18 PM
FLYOU's Avatar
I love hondas... but i hate their clunky transmissions. Vrrrrrrrrrrrrrrrrrom CLUNK Vrrrrrrrrrrrrrrom CLUNK Vrrrrrrrrrrrrrrrrrrom
Old Oct 26, 2008 | 09:42 PM
Macaco's Avatar
ORIGINAL: pacemaker
uhm i don't know what an irregular change in gears would be, but it feels fine, it shifts fine, its responsive, no slipping of any sort. So i guess i can eliminate gears..it might be the radiator, but theres no leak ..yet!!
Old Oct 26, 2008 | 09:44 PM
Macaco's Avatar
anythings a big help!! THANKS!
Old Oct 26, 2008 | 10:43 PM
Hurricane rider's Avatar
ORIGINAL: FLYOU
lol my hurricane sounded like that before I changed the oil in it. the transmissions on these bikes ARE clunky compared to my little EX500 I had before this.
Grenadesathand
Dec 20, 2012 03:03 AM
rsaari13
F2 Tech
Oct 24, 2012 10:52 AM
RoadRashHurts904
Apr 27, 2008 06:22 PM
Jaycbrf2
Jun 19, 2006 02:44 PM
cbr6
Aug 22, 2005 02:33 PM
