Gear problem
Old Jul 11, 2013 | 04:00 PM
jin27us@yahoo.com's Avatar
Default Gear problem
Hi,
I am worry about the clutch. When I accelerate hard on first and go 2nd, it doesn't seems to want to engage. Quit often I end up in neutral.
Also when I down gear from 2nd to neutral at around 60km or more,and than when I try to get to 2nd or 1st I will grind the gear. I will have to wait till it slows down before I can get out of neutral.
Basically if I am going hard and want to switch from 1st - 2nd or 2nd to 1st it doesn't want to cooperate.
I hope this is make sense. Please advise. Thanks
Old Jul 12, 2013 | 01:08 PM
YunMing's Avatar
normal. I'm upgrading to a shift star kit to avoid this with my next oil change
Old Jul 12, 2013 | 01:28 PM
aaront1988's Avatar
I found that just changing the oil with a decent oil made changing gears much smoother for some reason. Maybe in my mind but certainly felt a difference
Old Jul 14, 2013 | 06:25 PM
Kopi Ko's Avatar
+1 for changing oil. I used to feel strong kick when I advanced to 2nd gear. Right after I changed my oil, it went smooth
Old Jul 16, 2013 | 08:24 AM
Well I hope it is "normal". I will been trying to remind myself to make sure I give it a good kick when i up or down shift out of 1st and 2nd. And try not to shift down 2 far.
Recently I been rev matching, and it kind of help the problem 2. THanks guys. At least other have same problem... sort of makes it feel better. Safe riding!!
rangerdave1
Jun 20, 2010 11:09 PM
stewieG
Feb 27, 2009 08:57 PM
Jaybird180
Aug 29, 2008 09:09 AM
younngichols
May 22, 2006 06:09 PM
Shlock
Feb 7, 2006 10:39 AM
