fuel pump removal(brillo pad)?
Old May 2, 2009 | 12:50 PM
mralbdamminc's Avatar
June 2010 ROTM
Default fuel pump removal(brillo pad)?
ok so i take my fuel pump assembly off the tank and there looks to be some metal brillo pad thingy in the rubber boot around the bottom. is this supposed to be here?
Old May 2, 2009 | 12:52 PM
letsride's Avatar
yes it is.
Old May 2, 2009 | 01:09 PM
zoomin6's Avatar
yes, and make sure to buy a new gasket seal for the fuel pump before you put the pump back on because it will leak gasoline or wont seal properly...
Old May 2, 2009 | 03:43 PM
Berto's Avatar
And while you're at it, smear a little fuel lube on the gasket or Dow DC-4 or the like. It will improve the seal and keep the gasket from pinching.
Also, follow the torque guidlelines in the manual. If you overtorque, it's easy to strip those mount bolts and nuts.
The brillo pad this is the sediment screen, I believe, it should stay put.
--Paul
Kopi Ko
Sep 6, 2024 12:02 AM
pmcg
May 15, 2012 11:09 PM
bigbob65
Oct 19, 2009 04:09 PM
zblad
Dec 5, 2008 01:14 AM
TylerC161
Sep 28, 2006 01:52 PM
