87-88 Fuel Pump Removal
Old Sep 3, 2006 | 08:56 AM
TylerC161's Avatar
Default 87-88 Fuel Pump Removal
Just wanting to know if this is an option. I see all the other bikes pump-less, and I didnt know if the 87 was capeable of having it being removed.
Old Sep 3, 2006 | 08:21 PM
TylerC161's Avatar
Default RE: 87-88 Fuel Pump Removal
Anyone know for sure?
Old Sep 4, 2006 | 12:41 AM
hurricane1000's Avatar
i have not needed to try it myself, but our bikes work just fine w/o the pump, just let gravity do its thing.
Old Sep 4, 2006 | 11:43 PM
TylerC161's Avatar
I kind of answered my own question. the fuel is under the carbs on these bikes, theres no way the fuel can come from the bottom of the tank, to the bottom of the carbs, and still get sucked into the engine.
Old Sep 5, 2006 | 11:11 AM
i have seen 3 different 87-88 hurricane 1000's that had their fuel pump removed, so unless your carbs are sitting on top of your tank this will work. the carbs are below the lowest point on the tank, just bypass the pump and see for yourself.
Old Sep 6, 2006 | 07:18 AM
tomih84d's Avatar
im sure the people at honda put the pump on for a reason. if your running anywhere near wot thats a lot of fuel to be gravity bleeding.
Old Sep 6, 2006 | 04:17 PM
try it and find out. i know of 3 bikes running right now without a pump, and yes sometimes at WOT.
Old Sep 23, 2006 | 06:07 AM
yas001's Avatar
Hey gays, My CBR's fuel pump stopped working today at DMV after I registered. Then I removed fuel pump and drove back home about 20 miles without any problem. FYI...
Old Sep 23, 2006 | 06:54 AM
TylerC161's Avatar
any wide open throttle passes?
My bike is now leaking coolant, a friend dumped it, so, i cant use it much..
would you mind running it around the blocks a few times with some highway passes at WOT to insure it wont be needed?
Old Sep 23, 2006 | 07:20 AM
yas001's Avatar
TylerC161, I will try that tomorrow. Brand new fuel pump costs $145. If the pump will be needed, I will try generic electrical pump, however I learned the origial pump has integrated relay in it....
