Fuel Pump not coming on
Old 03-05-2009, 02:14 AM
CBR_SLIM_T's Avatar
Default Fuel Pump not coming on
Took my bike apart to paint it. Down to the last things, and I realize my fuel pump isnt coming on when I turn the key on. ( Kill switch in correct position)
I jumped the fuel pump directly to the battery and it comes on.
Is there a fuel pump fuse? What are some things i can trouble shoot? Please help asap. Need my back running by tomorrow for bike night!
THANKS IN ADVANCE!
Old 03-05-2009, 04:56 AM
skoobydoobie's Avatar
Plug your headlight harness back in. There is a BAS (bank angle sensor) attached to the headlight, in the middle on the backside, if it ain't hooked up your bike wont run.
Old 03-05-2009, 12:02 PM
CBR_SLIM_T's Avatar
Headlights are hooked up. Is there a fuse or relay I can check?
Old 03-05-2009, 12:47 PM
Stephens's Avatar
All of your fuses are located under your driver seat.
Old 03-05-2009, 05:01 PM
franz's Avatar
is your battery fully charged..
Old 03-06-2009, 05:09 PM
Tanknuts's Avatar
There is a fuse for the fuel pump. I cant remember what else that fuse runs, but my friend had the same problem with his F4i. We replaced the fuse and everything worked fine.
Old 03-07-2009, 04:41 PM
kev2369's Avatar
I am having the same trouble... Except I haven't had mine apart... It ran the last time that I got on it... Parked it for about a month and when I went to start it today, the pump doesn't prime and when I hit the start button the headlight just goes out and it does nothing... I've checked all my connections and even put di-electric grease on them just to make sure... Guess I'm going to the manual to see if I can trace it down
Kopi Ko
10-01-2019 08:29 AM
samba2
05-23-2012 11:12 AM
shorty22
07-24-2010 09:32 AM
knonfs
03-21-2009 05:02 PM
zblad
12-05-2008 01:14 AM
Quick Reply: Fuel Pump not coming on
