front brake resevoir
I'm not sure how to read it. Should it be read between the brass looking piece and the see through plastic? If so it's really low. Or should it be read by the gaps in the brass looking piece. It would be full then. I could just open it up and see, but if it's really full I might spill some depending on how the bars are angled.
If I need to add more I don't need to bleed right?
Thanks!
RE: front brake resevoir
It's full right now. That brown stuff is your brake fluid, buddy. It needs to be above the LOWER mark (the bar below the LOWER), which it is. If you need to add more, you don't need to bleed. Be careful with the brake fluid though. If it's left on your plastics, it'll destroy it. Clean it up immediately if spilled.
