front brake resevoir
Old Aug 18, 2007 | 04:45 PM
orientalexpress's Avatar
Default front brake resevoir
My mastercylinder/resevoir is leaking slowly, about a drop everytime I ride it. I need to fix it ASAP but do you need a whole new assembly or can you replace the internals? Can you buy a rebuild kit?
Old Dec 27, 2017 | 04:21 PM
Tee_YeeYeeeeee's Avatar
Unhappy HALP! Slow leak in front brake reservoir
Just bought a 2001 CBR600 f4i from a buddy who says the brake fluid was replaced during a full service tune up about 5 months ago but now it is slowly leaking every time I pull in the brake lever. It appears to be leaking out a pin that moves in and out at the joint connection of the lever. Do I need a whole new set up or is it a piece inside like some sort of gasket or something that can be replaced?
Old Dec 27, 2017 | 05:43 PM
74demon's Avatar
See if you can get a master cylinder rebuild kit. It's pretty simple to do.
Old Dec 28, 2017 | 12:26 PM
boredandstroked's Avatar
You can rebuild to stop the leak.
Old Dec 29, 2017 | 03:01 PM
Thank you, y'all. I'll look into this.
Old Dec 31, 2017 | 08:32 PM
ceebeeaarguy's Avatar
If it's leaking from where you are saying it's leaking then chances are the seal on the master cylinder piston was put the wrong way(if it was rebuilt, usually a brake fluid change happens with a rebuild of master cylinder and caliper etc)
But if there was no rebuild then I would be surprised it's leaking from there. Have you checked the reservoir? In my case, I overfilled the reservoir and fuid seeped out of the two tiny wholes either side of it and ended up on my brake levers as well!
cschew
Aug 1, 2014 02:10 PM
Wants a CBR
Apr 24, 2008 06:07 AM
clockworkcbr
Jul 25, 2007 09:20 AM
