f4i Front Brake Fluid Resevoir
Old Jul 30, 2014 | 11:15 AM
cschew's Avatar
Default f4i Front Brake Fluid Resevoir
Are you supposed to check the fluid in the front brake reservoir while the bike is on its side stand with the bar turned all the way to the left?
Bike is a cbr600f4i.
Old Aug 1, 2014 | 02:10 PM
highwaypatrol's Avatar
The best way to check the fluid in the front brake reservoir is to remove the plastic screen on the front of the fairing (8 plastic bolts) and turn the handlebars to the left as you say. If you can keep the bike upright you will keep the reservoir level and the top retaining screws will be easier to access for removal. I have just done a top up on my front brake reservoir after replacing the front brake pads. Always remove some fluid with a syringe before replacing pads as when you push the pistons in the fluid level will rise.
orientalexpress
Dec 31, 2017 08:32 PM
IronCityGuy
Jun 14, 2010 11:31 PM
Wants a CBR
Apr 24, 2008 06:07 AM
clockworkcbr
Jul 25, 2007 09:20 AM
