FI 1 Flash Map Sensor Issue
Ok, maybe some may know or have had this issue but I have not found it in any forums in here. I am receiving a FI 1 flash Map sensor code. how this started is after work I filled up my gas and headed home on the interstate, all of a sudden my bike died on me doing 55 mph and I was receiving a 1 flash Map sensor code. I got it home (no thanks to progressive) and tore it apart to figure out why. I looked at the map sensor and traced all wires (all good) checked all fuses (again all good) looked if it was injecting fuel and that's good, spark plugs are new and even rechecked them and they are good and get good spark. I spray starter fluid into the heads it cranks until it burns that off and dies again. Fuel pump primes (may be bad gas, will check that today because it did this after filling up). Thinking it may be the stator but when I checked voltage on the main things everything checked out to spec. So if anyone has anything or can point me into the right direction it would be helpful. Summer is almost up and I still want to get her up and going and enjoy her a little longer.
Yes, I did replace the Map Sensor with a new one, and yes checked all air hoses as well as the wires. I did follow the steps and even reset the FI code to see if there were any other codes but it only pops up with just that one code. I even today purchased new rubber hoses for the air and nothing....
cBrentb
10-09-2013 01:09 PM
cBrentb
09-09-2013 03:35 PM
kagmyster00
01-26-2009 04:40 PM
