f4i seat
Old Jul 6, 2011 | 03:39 PM
cuetip's Avatar
Default f4i seat
Anyone have any pix of how the drivers seat is supposed to sit on the gas tank since for some reason the front of mine doesn't want to latch on to my gas tank
Old Jul 6, 2011 | 03:43 PM
F34Me?'s Avatar
With mine I have to leave the two bolt/pins at the rear of the tank a little bit loose so the seat can get down in that bracket real good. I'd take the seat off and loosen up all the tank bolts then fit the seat and see where everything needs to be before you start tightening stuff down. Tighten bolts one at a time to see which one(s) are causing your issue.
Old Jul 6, 2011 | 11:43 PM
gotcbr's Avatar
You did the split seat conversion correct?
The front of the seat should have a plastic "hook" that inserts into the metal clip on your gas tank that's attached by two bolts. That plastic tab inserts btwn the tank & underside of that clip, securing it.
Insert that front plastic hook into the clip first. Once in, push down on back of seat. May take a little wobble to get it go.
Old Jul 7, 2011 | 08:07 AM
cuetip's Avatar
I did the conversion but now I no what I did wrong I don't have the little bracket that it goes into my fault for not explaining it well gotcbr what's that seat bracket called by chance
Old Jul 7, 2011 | 10:42 AM
gotcbr's Avatar
Front Seat Stay
djmnyc
F4i - Wanted
May 30, 2010 08:49 AM
TaoistTattooist
Aug 26, 2009 11:14 AM
sharker98
Jan 10, 2008 03:16 PM
fakemeoutrepsol
Mar 29, 2007 06:55 PM
