solo seat options for the but ungly banana seat
Old Mar 28, 2007 | 01:38 AM
fakemeoutrepsol's Avatar
Default solo seat options for the but ungly banana seat
other than the subframe complete swap from the 01-03 f4i's, are there any other solo tail swaps? i dont care if it has a fixed cowl(no passengerseat cushion), but it does need to be street legal compatible. i also need to find a underatail to go with it.
i found this on ebay http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=011&sspagename=S TRK%3AMEWA%3AIT&viewitem=&item=32009599931 9&rd=1,1
made of plastic, looks like a 01-03 replica, but the seller states it works on 01-06, does this make sense seeing that they have different rear tail subframes? i am also confused on what undertail to get, howdoes acustom tail piece bolt on to a model year specific undertail? will i have problems mixing and matching parts?
and these unbdertails
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=008&sspagename=S TRK%3AMEWA%3AIT&viewitem=&item=18009978833 6&rd=1,1
do you think these lights are big/bright enough for street use? or are these better/safer?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=008&sspagename=S TRK%3AMEWA%3AIT&viewitem=&item=18007208739 5&rd=1,1
they are both from the same seller and dont give specific years for fitment.
i know there are poeple here that have swapped out the banana seat and tail with something other than the 01-03 OE parts.[/align]
Old Mar 28, 2007 | 01:59 AM
Italio13's Avatar
Default RE: solo seat options for the but ungly banana seat
just take the route i chose and get the targa
Old Mar 28, 2007 | 03:24 AM
Leveltwo's Avatar
01-03 have a different subframe and undertray...so undertails and cowls will only work for those years....you need to find a cowl for a 04-06 year bike for it to work
Old Mar 28, 2007 | 03:50 AM
how about this one, solo tail that states it is for fitment on 04-06 F4I's, their are two available, one that uses the stock seat(banana) which covers over the rear section, and one that requires a new single seat pad.
they are from sharkskinz
http://www.sharkskinz.com/hondacbr600f4i.htm
assuming this is a bolt on piece, do you think that 04-06 undertail kits will be compatible?
Old Mar 28, 2007 | 03:52 AM
SchiraF4I's Avatar
http://www.sharkskinz.com/h/honda1090.htm
i like that one, but you lose your trunk use....
Old Mar 28, 2007 | 03:55 AM
ORIGINAL: Italio13
not bad looking, but i want somethin alittle sleeker, that and i want to never ever have the liability of a passenger. <---i know, its definately moistens the female occupants, but i dont like the risk(i wouldnt want someone experiencing what i have...waking up in da bambalance and eryting)maybe after i have been riding for a couple years i will allow some tang to ride along.
Old Mar 28, 2007 | 03:56 AM
ORIGINAL: SchiraF4I
looks so, i can live without the trunk space.....i think.....other than trnuk space, would it allow access to the fuse box? sorry, i cant even remember if the fuse box is below the front portion of the banana of the rear tail section?
Old Mar 28, 2007 | 04:07 AM
airtech has one listed too, but doesnt give model year specifics.
http://www.airtech-streamlining.com/...0F4i200104.htm
i guess i just need to call these bastids
Old Mar 28, 2007 | 04:19 AM
damn, they are definately out there, here is one from cheetah, im not sure why all these state they are available for the 01-03 as well as the 04-06's without seeing different part numbers? is it possible that both subframes can acceptthe sameaftermarket tail?
http://www.parts411.com/acbasp/store...267C14278.aspx
Old Mar 29, 2007 | 06:34 PM
looks like airtech makes a solo seat and a undertail that bolts on a 04+ F4I. it does need the tail light section to be cut out. It uses the stock banana seat and covers the rear with a perm fixed rear cowl-super bike style. i think this is the route i am going to take since i already ordered a devil high mount and devilbikes says the pipes are different on the 01-03 vs 04+ so a 01-03 tail section and subframe will not fit without modifications.
