F4i fuel pump not priming
Alright so heres the run down on what is going on..
I go into school and i always lock my bike. Well when i got off of school today i saw that the igniton was all broken someone had tryed to steal her and must have not known what they were doing because they couldnt get past that lock
.. well i took it home on my truck and started to take a look and saw that they also had some of the igniton wires spliced.. i found a way to get the bikes power on and its turning over but the fuel pump isnt priming so i read to use a jumper wire or something like that? well i did this and it works but the min. i turn the bike off it wont work again.. the FI light just stays on and no fuel pump prime what does this mean? THank you
That sucks that someone tried to jack your bike. If I remember correctly you need to follow the pink wire in your ignition and that will take you to a diode. You'll eed to measure the volts at the diode, you should be getting 9V I believe, if your not then you'll need to replace it. For more info type in "pink wire" in the search field and you should get some pretty solid results. Good luck!
when you flip the switch on and off yes it does click just no prime and fi light stays on and turns off when switch is turned off.. Tip over sensor? where is that located is that the sensor on the headlights or is that the bank angle sensor? thanks for the help you guys
with you head lights not turning on...do you have "brights" indicated on, on your cluster?? if you got that with out a fuel pump prime, but engine will still crank...check the main harness (green wire - ground for BAS - doesn't have continuity, most likely).
Alright soo i disconnected my battery and started too do what all of yall told me to do and i came out with great results the fuel pump is priming and i am now looking at trying to get some new fairings for my bike any good websites? i just want the stock red and black decaled ones
