f4i average running temperatures?
Old Mar 18, 2023 | 01:36 PM
dannoxyz's Avatar
Don't use Engine Ice, it is propylene-glycol and has only 1/2 thermal-conductivity of normal coolant, so bike will run hotter because less heat per second will be shed by radiator.
Use distilled water + Water Wetter for fastest heat-shedding rate. Will lower temps 10-15 degrees cooler than what you're seeing now.
I'm in Phoenix too and only see those temps you have when it's 110F out.
Old Mar 20, 2023 | 11:23 AM
MomosF4I's Avatar
I've been using distilled water + Water Wetter since I purchased my F4i and very pleased with the results. Most of my friends have switched over, especially those with older sportbikes.
I think OP's temp spike could be a simple air pocket in the system.
Old Mar 22, 2023 | 01:31 PM
Nthardee's Avatar
Default F4i temping and running slow
Also give your throttle a little choke and up rev in between gears make sure you have a nice pulsing idle in slow riding you have injectors that run under 4,000 rpms and the bike Will go above 200 when hot out side and the more you use the engine the more it will use your coolant sysytem. Especially with custom exhaust on those. Im on my second fuel pump assembly and gasket on mine.
03F4iAddict
Jun 24, 2009 12:46 PM
91lx50udlose
Mar 29, 2009 10:55 PM
gursh d
May 5, 2008 07:55 PM
smak_blaze
Jun 18, 2007 09:29 PM
snowboarding82
Jul 20, 2006 01:39 PM
