Ever see this? White gunk.
Old May 6, 2008 | 03:22 PM
muckdawg24's Avatar
Default Ever see this? White gunk.
Anybody seen this crud buildup on their tach? I think the plastic melted cause it won't come off!
Old May 6, 2008 | 03:43 PM
redzintimidator's Avatar
Default RE: Ever see this? White gunk.
Is it on the inside or outside?? What cleaners do you use on your bike? I used some armor all rim cleaner to get off the grease and clean the rims. I got some on my pipe and it stained it white a little...
Old May 6, 2008 | 05:33 PM
whtan20's Avatar
I had that, but it was on my gas tank and right fairing too, from what i figured either someone threw milk or white watered down paint at my bike because it came off. Good luck with yours.
Old May 6, 2008 | 07:00 PM
muckdawg24's Avatar
I never have cleaned it with anything but water and a cloth. I think the sun messed it up. It's only on the tach, which is weird, Da*nit!
Old May 6, 2008 | 07:17 PM
krash's Avatar
could be brake fluid, bird ****, ***, spit
Old May 6, 2008 | 08:29 PM
TBFGhost's Avatar
if it is on the outside, go get rubbing compound, something like3M Perfect-It III and use that, it should clean it off if it is not too bad and will also take away light scratches and make it very shinny again
http://www.amazon.com/3M-Perfect-Rub.../dp/B0002NUNB6
Old May 7, 2008 | 10:30 AM
Tahoe SC's Avatar
i agree with krash...
it's BWATTTTTTTT!
JankCibberf2
Sep 6, 2012 10:02 PM
superjuicebox2
Jul 23, 2012 11:31 AM
candyf3
Aug 12, 2011 07:57 AM
CBRwarrior
Mar 31, 2008 09:06 PM
Frogleg311
Nov 15, 2005 04:18 AM
