valves knocking.
Old May 6, 2008 | 09:56 AM
dienasty13's Avatar
Default valves knocking.
sounds like i could use a Valve Adjustment, because the bike is very radily sounding when reved at about 4-5 grand. I was planning on taking it apart and doing it myself, but wanted to wait till winter you think the bike will be fine or should i just take the time and do it now? Any advice for when i do change them out?
Old May 6, 2008 | 10:38 AM
kneepuck oo envy's Avatar
Default RE: valves knocking.
how many miles do you have? chances are youre mistaken it with the CCT-L...
Old May 6, 2008 | 10:55 AM
Ruftags's Avatar
+1 on CCT Would almost bet money on it. Do a search and see if disciptions match your symptoms.
Old May 6, 2008 | 10:56 AM
dienasty13's Avatar
i have almost 30,000 on the bike im sure its not the CCT-L the actual engine is knocking sounds like a bolt is loose in the engine no back fire or metal chips fireing out the exhaust yet...
Old May 6, 2008 | 11:07 AM
StreetPower's Avatar
it's the cct sound, believe me, does the sound disappear about 6k rpm?
Old May 6, 2008 | 11:11 AM
Ruftags's Avatar
If it's knocking that bad Wouldn't you here it through all range of RPM's. Does it sound like it's coming from right under the gas tank, on both sides?
Old May 6, 2008 | 11:13 AM
dienasty13's Avatar
yeah it does. I thought the CCT sounded like a constant wrenching noise when the bike is coasting. Why would the CCT make such a rough noise? Is it really that big of a part maybe someone could elaborate for me? I was for sure the engine was knocking. Oh well thanks i guess...
Old May 6, 2008 | 01:22 PM
600f4i_blackout's Avatar
Here's a thread that may help you when the time comes around. It shows step-by-step on a 600RR, but should be the same thing for almost all CBR's:
http://cbrworld.net/forums/thread/248256.aspx
Old May 6, 2008 | 01:57 PM
dienasty13's Avatar
hey bro thanks! that helps visually alot!
Old May 6, 2008 | 04:01 PM
if you want a writeup on the F4i specifically:
http://www.bayarearidersforum.com/fo...threadid=85499
see, im telling you guys we need the stickies and FAQs i linked
