Electrical Problem. Ideas?
Old Mar 28, 2016 | 06:53 AM
PiotrTheGreat's Avatar
Default Electrical Problem. Ideas?
Took it to a shop, still have no idea what it could be
Old Mar 28, 2016 | 08:17 AM
Zealot's Avatar
I'm a total amateur in regards to this, but could it be shorting out? I'd be checking connectors, wires, fuses, etc. Regular and rectifier too while you're at it.
What'd the shop say?
Old Mar 29, 2016 | 10:12 AM
Shop said "stripped screw on positive battery terminal"
They put a new screw on, I'm still getting this
Old Apr 1, 2016 | 07:53 PM
Joe Rogers's Avatar
I hope you didn't pay for that diagnosis! First thing I would do is put a meter on the stator and see what its putting out. This wont fix your problem but if your regulator is putting out too much then you can easily fry electronics. I don't have experience with this on bikes, but I have seen it more than once on cars.
Old Apr 1, 2016 | 09:00 PM
Zealot's Avatar
You're going to have to start running various tests. I'd grab a meter and check what's going where.
Does the bike only lope like that when it's in neutral? Does rain have any effect on it? You said it in the video, but perhaps it was a slip of the tongue. If it only does that loping in neutral, you could very likely zero in on the potential cause by figuring out where anything related to the neutral light and such happens to be. Could be corroded connectors somewhere.
Old Apr 7, 2016 | 04:18 PM
Sam Scaife's Avatar
guys i had this problem. if you installed led turn signals this will happen. They stay on because the loop is not complete. Look in the random conversations for my little long story. :P hope it helps. (THis can effect your charging capabilities as well.... like mine)
Little edit" check your front wire harness. Pull it apart and check all grounds. the way it strobes looks like bad grounding... also check your connector to the main harness for any damage.
Old Apr 8, 2016 | 04:12 AM
Can this be fixed by installing a relay?
I HAD LED turn signals on the front of the bike when I got her, but they've been pulled off by this point
I'll check the harnesses and see if there's anything weird going on. Thanks
kwood
Jun 1, 2020 09:53 AM
revilingfool
Mar 19, 2011 02:49 AM
hatchtegman
Sep 1, 2010 03:15 PM
NMRider
Jul 10, 2007 05:29 AM
JBaz
Nov 10, 2006 05:10 PM
