Electrical is dead, any ideas?
Old May 12, 2007 | 11:34 PM
NMRider's Avatar
Default Electrical is dead, any ideas?
Went on a 150 mile ride today and 3 miles from home it starts to rain and bike starts bucking like it's out of gas. Just filled so I know that's not it so Ipull over just as it dies all together. No lights, horn or nothing - battery has a charge and connections look good. Any help would be appreciated.
NMRider
Old May 13, 2007 | 10:15 AM
keymandave's Avatar
Default RE: Electrical is dead, any ideas?
Hi, I have a problem with my electrics also, but this sounds like what happened to my friends bike. I think he said his wiring had burnt out from the regulator . He had to replace stator & rectifier and the it was sorted, hope this helps I'm no expert. I'm sure someone on here will help more, cheers.
Old May 14, 2007 | 01:17 AM
NMRider's Avatar
How do I troubleshoot the rectifier? Also, should I post this in the General Tech forum instead of here?
Old May 14, 2007 | 09:25 AM
edwardtn's Avatar
Do a search...thereare probably 100 posts about trouble shooting the RR....with a good test set you can test the RR and stator.
Old May 16, 2007 | 07:53 PM
NMRider's Avatar
Update: battery has charge (12.8v) with key off and no charge when key is switched on. Rectifier wires test good (green has continuity to ground, yellows don't, and red has battery voltage) 30a fuse is good and the three 10a and one 15a fuse is good. But, there is no voltage from the ignition module plug black wire to ground. Still no lights, horn, start button, etc...
Old Jul 7, 2007 | 07:57 PM
FNQuickF2's Avatar
Take a look at the fuse right above the rear shock damper...That one might be blown...It is at the top of a little box there..
RB
Old Jul 7, 2007 | 09:59 PM
21cbrf2's Avatar
Did you actually check the connection to the battery or look at them? The sputtering sounds like what my bike did and it was the connections to the battery. check to see if they are tight if you haven't already.
Old Jul 7, 2007 | 10:56 PM
MikeInCtown's Avatar
Sure sounds like the water shorted something in a connection. At first I would have said that the wires were bad and grounded when they got wet, but it almost sounds like you have a short in the ignition or something.Good luck tracing the problem.
Old Jul 10, 2007 | 05:29 AM
NMRider's Avatar
Update, I replaced the rectifier and battery and all has been good.
Thanks for the help.
dodger79
Jan 23, 2014 12:42 PM
Rooski
Mar 25, 2010 11:50 AM
soon2Bturbo
Nov 15, 2007 12:28 PM
TennesseeCBRF2
Aug 1, 2007 01:32 PM
NMRider
May 20, 2007 02:55 AM
