Ebay Ignition switch
Old May 27, 2010 | 09:32 PM
usetheffours's Avatar
Default Ebay Ignition switch
This is what I bought for a friend of mine Ignition switch and gas cap.
I got it to replace the old one that someone had broken so they wouldn't need a key . However the wiring plug from the switch doesn't fit the factory harness. The switch only has 3 wires instead of 4. Also it will not work because it doesn't have a diode that is needed.
However If you happen to need one of this cheap replacements I figure out how to make it work. You need the diode off the old ignition switch. Solder it between the pink wire from the bike harness and the black/red wire from the switch or harness.
Anyway thought I would share after my 2 hour job turned into 6
ObsidianOne
Jan 14, 2014 03:21 PM
kyeman11
Jun 1, 2009 04:51 PM
nutter
May 5, 2009 10:58 AM
new929
Mar 10, 2008 03:37 PM
