Ebay Ignition switch
This is what I bought for a friend of mine Ignition switch and gas cap.
I got it to replace the old one that someone had broken so they wouldn't need a key :icon_shrug:. However the wiring plug from the switch doesn't fit the factory harness. The switch only has 3 wires instead of 4. Also it will not work because it doesn't have a diode that is needed. :mad: However If you happen to need one of this cheap replacements I figure out how to make it work. You need the diode off the old ignition switch. Solder it between the pink wire from the bike harness and the black/red wire from the switch or harness. Anyway thought I would share after my 2 hour job turned into 6 :icon_doh: |
