Coolant leak
Old Nov 6, 2013 | 10:47 PM
stewyF4i's Avatar
Default Coolant leak
Has anyone else had problems with coolant leaking out the bottom of the water pump. I'm guessing it's just the gasket it looks like that's where it's coming from. My bike has never leaked anything I came home from being gone for a weak and there's to little puddles of coolant under the bike temp maybe down to 35 degrees. One right under water pump the other 10 inches in front of that not sure where that was coming from. Just seeing if anyone else has seen this??
Old Nov 6, 2013 | 11:25 PM
74demon's Avatar
The water pump will leak from the weep hole when the internal seal or bearing go out. Do yourself a favor and replace it before it fails completely.
Old Apr 17, 2014 | 10:56 PM
COB's Avatar
COB
I just pulled my bike out of the garage from winter and had coolant on the ground. I can't tell where it came from yet. I'll be pulled the fairings off tomorrow. Is it difficult to replace the gasket or seal?
gump
Apr 9, 2011 10:00 PM
Ragnar1x
Apr 9, 2011 09:29 PM
dominiksi
Feb 7, 2009 12:17 PM
phamtastic0
Feb 5, 2008 02:21 PM
mattyg
Apr 26, 2007 02:58 PM
