Coolant leak )-;
Old Apr 25, 2007 | 10:42 PM
mattyg's Avatar
Default Coolant leak )-;
This F4i has about 12k miles on it. I've never had any problems with it (the downed scratches are from a previous owner). This just started recently and after I replaced my oil pan. I can't see how that would cause a coolant leak tho. It's definitely not oil because it's green. Any thoughts on where this coolant is coming from? It only seems to leak very slightly after being ridden. Please see pic. Thanks for any help.
[IMG]local://upfiles/12352/A1A2DECF814B4AE9BAE4DD561A5964D7.jpg[/IMG]
Old Apr 25, 2007 | 11:52 PM
95camaro01f4i's Avatar
Default RE: Coolant leak )-;
ORIGINAL: mattyg
you sure it isnt comeing out the over flow hose
Old Apr 26, 2007 | 12:22 AM
Stephens's Avatar
If you have too much coolant it will overflow onto the ground. Like a car, or it could be your air conditioner too. lol
Old Apr 26, 2007 | 01:35 AM
mattyg's Avatar
I've never added any coolant to this bike. . .it never looked low. So I don't know why all of a sudden I would have too much coolant.
It's definitely not coming from the overflow hose. The leak is more foreward than where the hose hangs.
Old Apr 26, 2007 | 10:16 AM
CBR_Rod's Avatar
I've noticed from time to time either of my bikes might have a drop of coolant or two at the bottom of the over flow hose. Bought both bikes new, never done any work with the coolant.
Installed an SAE cable on the F4i last night and I noticed the coolant tank level was flush with the lower lever.
Old Apr 26, 2007 | 01:18 PM
Tahoe SC's Avatar
only thing you can do is trace it to see where it's coming from.
could be just loose hoses.
Old Apr 26, 2007 | 02:58 PM
turn the light off in your garage and get a really really good black light the cheap ones dont work good. that might help u find it
gordo993
F2 Tech
May 19, 2012 12:59 PM
gump
Apr 9, 2011 10:00 PM
Ragnar1x
Apr 9, 2011 09:29 PM
dominiksi
Feb 7, 2009 12:17 PM
phamtastic0
Feb 5, 2008 02:21 PM
