i need some HELP!!!!!!!!!!!!!!!
Old Apr 26, 2007 | 03:31 AM
DTS_aka_cboe's Avatar
Default i need some HELP!!!!!!!!!!!!!!!
i want to get a power camander is it good or what and how much power will i gain?
Old Apr 26, 2007 | 05:10 AM
suicidal's Avatar
Default RE: i need some HELP!!!!!!!!!!!!!!!
grrr. search search search so many things you can read up on.
after searching for you:
https://cbrforum.com/m_2814/tm.htm
the power commander is there to make your engine run properly. your stock ecu is only able to compensate so much when it comes to air/fuel. normally, the ecu is just fine. when you start adding a slip/full system thats when the pc is needed.
a pc will give a couple of hp but not alot. its there to smooth everything out. the only way to know if your engine is running right WITHOUT putting it on the dyno is with a wide band commander. personally, i like the wide band route vs. the dyno route. its able to log 10 minutes of REAL WORLD riding.
https://cbrforum.com/m_168538/tm.htm
Worth every penny. Even if mine breaks I will buy another one.
Old Apr 26, 2007 | 05:44 AM
ddaren's Avatar
one thing i can say...get it only if you're gonna use the power and go fast.
I have a lot of friends with bikes... some race, some don't. the ones that race love PC's. the ones that don't race sold theirs because they didn't exactly make full use of it.
Old Apr 26, 2007 | 05:55 AM
formulafire99's Avatar
I just installed one on mine with my micron carbon high mount and I can tell a huge difference. I don't have a surge at idle and great throttle response. Best money I have spent, exept for my gear of course.
Old Apr 26, 2007 | 08:01 AM
HAVOC's Avatar
boe dont you have to repair your bike 1st AND heal up from your crash beofre you start thinking about getting a pwr cmndr ?
Old Apr 26, 2007 | 04:56 PM
i geuss but im almost healed and ive almost got my bike done justwaitin on a few parts and then im done!!!!
