Coolant Leak
Old Apr 9, 2011 | 04:41 PM
Ragnar1x's Avatar
Default Coolant Leak
I just started my bike up the first time this year and noticed coolant was leaking so I shut it off. (It was running fine for about 10 mins before the leak started) I did not have a coolant leak last year. It looks like its leaking in a few different places, water pump bolts, alternator cover bolts, and somewhere else inside. I don't see oil in the coolant. Could it simply be that the o-rings and gaskets just went bad over the winter? It was stored inside, but unheated.
Its an 04 with 12,000 miles, and I rode it maybe 1000 miles last year.
Old Apr 9, 2011 | 07:21 PM
Matt5606's Avatar
Water pump bolts sound like the pump gasket is leaking. As for the others, i'm not too sure. Mine is leaking a bit as well around the water pump. Gonna replace the $4 gasket and hope that solves the issue.
Old Apr 9, 2011 | 09:29 PM
cnicosiaF4i's Avatar
My bike had a coolant leak this spring and all I did was flush the coolant and it went away . I guess as long as its not leaking from the weep hole on the back side of the water pump the worst it could be is a new gasket
gordo993
F2 Tech
May 19, 2012 12:59 PM
gump
Apr 9, 2011 10:00 PM
dominiksi
Feb 7, 2009 12:17 PM
phamtastic0
Feb 5, 2008 02:21 PM
mattyg
Apr 26, 2007 02:58 PM
