Condensation under headlight cover
Well I'm riding my '05 F4i in Michigan and we had temps about 50 today and sunny. I noticed when I put my bike back in the garage that there was moisture inside the high beam head light side but there wasnt any on the low beam side. It was during the day so I didnt have the high beam on at all. Didn't know if the headlight unit is supposed to be a closed unit which would not allow any moisture in or if it is normal. My bike is still under warranty until June '07 so wanted to know if I should take it in to get it fixed or just leave it be. Thanks for the input.
RE: Condensation under headlight cover
I would think that was not normal i live in texas and my bike stays out side even when its around freezing and also when its 100+ and i have never seen condensation in the my healights. I would run that bike over to the dealer and have them reaplace that headlight assembly and check to see if the headlight bulbs are mounted flush so no moisture can get in.
Most headlights are definetly NOT a sealed system, air enters and exits as the bulbs inside the headlights heat up and cool down. Just run your high beam and it will heat up the air inside, drive it out and dry it up. It's exactly like you said, your high beams wore not on, so the more humid air inside never escaped. If it was a sealed system, there would be some significant pressure build up when the air heated up inside... trust me. I just blew up a glass today with heating air... long story, but safe to say you just need to run your high beam more. Problems do happen when part of the headlight doesn't get any warm air to evaporate out the moisture, like in car headlights sometimes turn signals don't get any heat and build up moisture inside. But for a bike, you shouldn't have any problem if you run both lights often.
Tip for fixing it quickly, take out the bulb, and put a hair dryer in there for a while, should heat up the air inside, and like someone said, leave it open over night. Once it's equalized, shouldn't be a problem. If it's really a problem, take a bit of dessicant you find in your shoes or at home depot, toss it in a nylon bag and stuff it in the headlight somewhere not hot.
JeremyGSU
03-17-2009 04:04 PM
