headlight condensation
Old May 1, 2007 | 05:32 PM
RZRS614's Avatar
Default headlight condensation
Anyone know of the best way to remove headlight condensation without breaking the seal on the housing. I heard a hairdryer would work, or i was thinking of just taking my highbeam light out and tieing a cloth to the end of a closehanger or something and trying to wipe it out. The highbeam side of the headlight housing fogs up reaaal bad when its humid out and looks like ****.
Old May 1, 2007 | 06:15 PM
Daemian's Avatar
Default RE: headlight condensation
sry i dont have a solution for u, but while you are at it... put in some HIDs
Old May 1, 2007 | 07:04 PM
Draconius's Avatar
If you get it once that means there is probably already a compromise in the seal. If you get it to go away, chances are it will come right back.
Old May 1, 2007 | 07:47 PM
ampfp's Avatar
The problem might be recurrent. i have a similar issue, but its not too bad. Just turn the high beam on for a while (or all the time for visibility!). that heats up the insides and clears up the fog within minutes.
Old May 1, 2007 | 09:46 PM
BadAzF4i's Avatar
yea it probably means the seal is broken somewhere and unless u replace the seal it will just happen over and over
Old May 1, 2007 | 10:36 PM
scatman's Avatar
Turn on the high beam to try and evaporate it. If that doesn't work, find the smallest, tiniest drill bit that you have a punch a hole in one corner of the headlight. Works every time.
Old May 1, 2007 | 10:59 PM
Daemian's Avatar
hey, not to hijack or anything but...
during the day do you all ride around w/ ur highbeams on? it seems to me that it would make me more visible and it doesnt seems to be blinding. my only concern was if it will burn out the bulb really fast, or get to hot for the headlight housing... it shouldnt, but i figured its better to ask then learn the hard way
Old May 1, 2007 | 11:16 PM
f4i guy's Avatar
+2 on what Scatman said, drilling the headlight works like a charm, it allows air to enter the headlight and dry up the condensation.
Old May 1, 2007 | 11:20 PM
f4iguy8804's Avatar
Yeah, I usually ride with the hi-beam on during the day. I figured the same as you- easier for people to see me. But to be honest, I never gave the housing gettin' hot a thought. Anyone else?
Old May 2, 2007 | 12:55 AM
FFCBRf4i's Avatar
same here...i ride throughout the day with my high beams on. i don't think i've ever just put low beams on...
Davidth93
Jul 16, 2009 12:22 AM
cyber00677
Aug 3, 2007 03:57 PM
elbaguy
Nov 25, 2006 03:28 AM
rookie600rr
Feb 16, 2006 04:30 PM
