digital speedo
Old Nov 23, 2006 | 10:15 AM
triplefivedrew's Avatar
Default digital speedo
Hi,
My digital speedo is reading zero some of the time (not just when stopped!!). its working 50% of the time.
I'm guessing there's a loose connection, can anybody tell me where it connects and how I might troubleshoot it?
thanks,
Drew
Old Nov 23, 2006 | 04:45 PM
ddaren's Avatar
Default RE: digital speedo
This happens to me also... but not 50% of the time. A little less than that.
My FI light also comes on when it happens, does that happen to you also?
I'll keep an eye on this thread cuz I wanna know what's wrong with out bikes.
Old Nov 23, 2006 | 07:12 PM
2003F4iDude's Avatar
Sounds like mabe your speed sensor is comming disconnected. It is located directly below the top of your rear shock on top of the transmission it has 3 wires green pink and black check the connection there. Mabe that could fix the problem?
Old Nov 23, 2006 | 07:47 PM
trixtrem's Avatar
happened to me, the speedo sensor is just a haul effects switch(magnetic) and after a while can go bad, i thought it was my switch block b/c if i flickd the kill switch as i was movin it would come back, !!!.. NEway bought a cheap one off ebay, and put it in and havent had a problem since.... hope this helps..
peace
Old Nov 25, 2006 | 03:46 PM
Thanks for the advice. Its a hard thing to access that's for sure. 2 hours later and still struggling.
Seems to work better after a few miles so fingers crossed for corrosion.
Ddarren, from what I've found, if the FI light is coming on then it knows of a specific problem, the self diagnosis ideas relating to speedo are:
Loose or poor contact on vehicle speed sensor connector
open or short circuit in speed sensor
faulty speed sensor.
... really helpful then.
jneal1531
Apr 19, 2014 01:04 AM
Meeks
May 12, 2007 01:09 AM
TennesseeCBRF2
May 4, 2007 03:57 PM
triplefivedrew
Nov 22, 2006 01:01 PM
