Clutch Question
Old Mar 5, 2008 | 01:28 PM
AchillesGone's Avatar
Default Clutch Question
Still working on the wrecked bike. The left handle bar is off the bike, so I decided to check on the clutch cable, near the engine. I disconnected the cable and begin moving the lever (on the engine) back and forth. I was SURPRISED to notice the lever:
1) Doesn't spring back to orignial position vigorously. Shouldn't it??? Is the return spring not very strong?
2) When pushing the lever backwards, it rotates almost fully backwards, about 3/4 of the way. Again seemed odd.
Pretty pathetic post, but I'd appreciate any info from someone who's recently worked on their bike. THANKS!
G
Old Mar 5, 2008 | 02:49 PM
Default RE: Clutch Question
hi
Old Mar 6, 2008 | 04:08 PM
Leveltwo's Avatar
The clutch lever is kinda cheap on these bikes, you may need to lube something up by the connection to see if it gets better, and i dont quite kno what you are talking about as for the lever rotating back, do you mean when you push it away from the bar it goes that way? like opposite it should. It sounds like you need a new line and lever to me
Old Mar 6, 2008 | 04:25 PM
ampfp's Avatar
If you disconnect the clutch cable there's no tension on the lever. the spring's at the crankcase. Dont get what you mean by rotating and moving backward.
Old Mar 7, 2008 | 04:04 PM
What I mean is: the lever by the crankcase. (With the cabledisconnected) WhenI pull it forward by hand (clutch engaged), it comes real easy. WhenI let it go, it barely returns to normal position. Once in normal position, if I push it backward, it rotates almost 3/4 of a circle. It just seemed real loose and pathetic. I was just curious of all f4i's were this way???
Old Mar 8, 2008 | 08:00 PM
gr8's Avatar
gr8
Hmmm i think your return spring might be bad. I went to check it on mine and its very hard. I told my brother to pull in the clutch and i tryd to hold the lever from moveing back and it just pushd my hand back. I took some pics sorry their kinda dark bike is next to a wall didnt feel like moveing it.
Here is another view with the clutch lever out
Here is the view witht the clutch lever pulld in. It only moves a few mm
I hope this help you out. Ill see if i have time on sunday to take the cable off and see if the lever will turn like yours.
Old Mar 8, 2008 | 08:19 PM
MC_spirited's Avatar
I thought the f4i's have hydraulic clutches, no?
Old Mar 9, 2008 | 01:29 AM
gr8's Avatar
gr8
Nope dont think so. I dont think it would be that hard to make it. All u need is another master and a slave cylinder and route some lines thats all. I dont know if bikes have pressure plates like cars do. But if you could get like a Stage 3 like you can for a car then u need a lot of help to compres that pressure plate. I think thats only reson u would need hydraulic. But why go thru all the extra work [sm=sleeping.gif]
idrivea3
May 9, 2010 12:03 AM
02f4irider
Mar 6, 2009 07:50 PM
lakaiguy
Nov 8, 2008 10:54 AM
SNOWMAN
Feb 6, 2008 03:26 PM
Stray Cat
May 1, 2007 02:21 PM
