Cluster Issue
Old Oct 27, 2022 | 08:36 AM
CbrDan600f4i's Avatar
No need. If it sweeps during startup, then you have a different problem than what I had.
Does the speedometer work? If it does then you may have an issue with your tachometer sensor.
Old Oct 27, 2022 | 09:16 AM
Jeremymrsn12's Avatar
Default Tach needle don’t work
Yes everything else and all lights work . It worked when I put it on like 6500 miles ago ,cluster was new .
the tach wire itself is just not getting enough power but don’t know why. He battery is putting out the correct volts but enough power is not maki g it to the tach . I put I separate jumper wire from battery to the connection pin where it plugs into back of cluster and when I rev engine the needle is jumpy but at least it respond to throttle . But only sweeps at key turn without the jumper
Old Oct 27, 2022 | 09:44 AM
To me it doesn’t sound like a ground or power issue coming into the cluster. It sounds like a signal issue. I’d test the tach sensor and the connectors between the sensor, cluster and power. Look for loose or corroded connections along the way. If there’s a ground issue it would be associated with the sensor not the cluster.
FYI - It may be difficult to troubleshoot the tach sensor because it’s not a constant DC voltage it’s a pulse waveform.
Old Oct 27, 2022 | 06:05 PM
Default Tach needle not working
Lord this is why I’m not a mechanic .
I did see when I turn the key on bike not running that the battery volts is 12.3
but when I start the bike volts drops to 7 or 8 I hooked a marine battery to bike battery and the same result volts drops to 8 volts . when started .
I replaced ecm with one from ebay because I can’t find a new one . So there is 200.00 wasted . May just drive it without tach and call it . May just replace speed sensor for ****s and giggles and if that don’t work well my my
Old Jan 13, 2023 | 07:25 AM
daryel.corran's Avatar
that should work. You can put 12v to a bare cluster no bike and everything lights up. It’s gotta be a bad cluster.
William Sprague
Aug 21, 2019 04:42 PM
cam and corona
Jan 31, 2013 11:10 AM
apatel
May 29, 2011 04:23 PM
Solsykness
Apr 27, 2011 07:39 PM
rockdj
Jun 30, 2010 09:41 PM
