Cleaning screws, bolts, and other metallic parts
Before i get started, i'm sure this was answered somewhere, far far away, in a galaxy known as the search function.
I looked, didn't find the answer i was looking for, so i started this thread.
I'm replacing my sprockets and chain, and everything is so disgusting and dirty, and everything i use won't get these nuts and bolts clean. What have you guys used to get these things clean? I mean specific brand and name of products. What do i have to look for at my local home depot, sears, autozone, or w/e.
Thanks guys! I appreciate the feedback.
Kerosene or diesel is better, has a lower flash point, i use diesel usually. It will get the trick done.
I usually use an old coffee can and put a little fuel in it then dump the bolts in it and swirl them around then use the brush to get any stubborn spots. Just let them soak for a few mins. Dont put anything rubber in there, such as your chain since it has o-rings in it.
Sometimes the simple things work a lot better than the 'specialty' stuff sold in stores.
Maybe you could wet the bristles on a toothbrush with kerosene and scrub the threads and other areas, then hit it with a blast of WD-40 or brake parts cleaner if there are no rubber parts as already mentioned.
Blue Scotts shop towels would help clean up for minimal costs.
This is the best parts cleaner I have ever used it's soooo awesome u spray and then it will dissolve the oil grease and grime then it really just evaporates !
I used this on my fork tubes to clean the inside cleaned everything No more oil or any kind of residue...!!! There is a warning about not using on rubber...
It's 3.99 for a bottle! great stuff!!
