Cleaning screws, bolts, and other metallic parts
Before i get started, i'm sure this was answered somewhere, far far away, in a galaxy known as the search function.
I looked, didn't find the answer i was looking for, so i started this thread. I'm replacing my sprockets and chain, and everything is so disgusting and dirty, and everything i use won't get these nuts and bolts clean. What have you guys used to get these things clean? I mean specific brand and name of products. What do i have to look for at my local home depot, sears, autozone, or w/e. Thanks guys! I appreciate the feedback. |
Soak them in gas, and use a stiff bristled brush.
Just regular gas station gasoline? Nothing else? or any particular gas?
Kerosene or diesel is better, has a lower flash point, i use diesel usually. It will get the trick done.
I usually use an old coffee can and put a little fuel in it then dump the bolts in it and swirl them around then use the brush to get any stubborn spots. Just let them soak for a few mins. Dont put anything rubber in there, such as your chain since it has o-rings in it. Sometimes the simple things work a lot better than the 'specialty' stuff sold in stores. |
+1 to the above, I clean all my metal parts with diesel, even the inside when it's rebuild time
i use break free CLP cause it cleans, lubes, and protects i also use it to clean my guns and fishing tackle.
Any kind of engine degreaser works great for me. Spray on and let it soak in
Maybe you could wet the bristles on a toothbrush with kerosene and scrub the threads and other areas, then hit it with a blast of WD-40 or brake parts cleaner if there are no rubber parts as already mentioned.
Blue Scotts shop towels would help clean up for minimal costs. |
Fella, you've got the right idea. I was doing something similar. The gasoline/kerosine/diesel technique definitely works like a charm. Thanks for the tips guys!
http://www.traxxion.com/images/produ...TCC1102010.jpg
This is the best parts cleaner I have ever used it's soooo awesome u spray and then it will dissolve the oil grease and grime then it really just evaporates ! I used this on my fork tubes to clean the inside cleaned everything No more oil or any kind of residue...!!! There is a warning about not using on rubber... It's 3.99 for a bottle! great stuff!! |
