Cleaning screws, bolts, and other metallic parts
Old Mar 6, 2011 | 10:20 PM
Dragondima's Avatar
Default Cleaning screws, bolts, and other metallic parts
Before i get started, i'm sure this was answered somewhere, far far away, in a galaxy known as the search function.
I looked, didn't find the answer i was looking for, so i started this thread.
I'm replacing my sprockets and chain, and everything is so disgusting and dirty, and everything i use won't get these nuts and bolts clean. What have you guys used to get these things clean? I mean specific brand and name of products. What do i have to look for at my local home depot, sears, autozone, or w/e.
Thanks guys! I appreciate the feedback.
Old Mar 6, 2011 | 10:23 PM
DagonRais's Avatar
Soak them in gas, and use a stiff bristled brush.
Old Mar 6, 2011 | 10:37 PM
Dragondima's Avatar
Just regular gas station gasoline? Nothing else? or any particular gas?
Old Mar 6, 2011 | 11:15 PM
DagonRais's Avatar
Kerosene or diesel is better, has a lower flash point, i use diesel usually. It will get the trick done.
I usually use an old coffee can and put a little fuel in it then dump the bolts in it and swirl them around then use the brush to get any stubborn spots. Just let them soak for a few mins. Dont put anything rubber in there, such as your chain since it has o-rings in it.
Sometimes the simple things work a lot better than the 'specialty' stuff sold in stores.
Old Mar 8, 2011 | 10:57 AM
Slick 6's Avatar
+1 to the above, I clean all my metal parts with diesel, even the inside when it's rebuild time
Old Mar 12, 2011 | 05:23 PM
HydroPrelude85's Avatar
i use break free CLP cause it cleans, lubes, and protects i also use it to clean my guns and fishing tackle.
Old Mar 12, 2011 | 05:28 PM
MuscleswitCBR's Avatar
Any kind of engine degreaser works great for me. Spray on and let it soak in
Old Mar 13, 2011 | 06:12 AM
fella's Avatar
Maybe you could wet the bristles on a toothbrush with kerosene and scrub the threads and other areas, then hit it with a blast of WD-40 or brake parts cleaner if there are no rubber parts as already mentioned.
Blue Scotts shop towels would help clean up for minimal costs.
Old Mar 13, 2011 | 10:05 AM
Dragondima's Avatar
Fella, you've got the right idea. I was doing something similar. The gasoline/kerosine/diesel technique definitely works like a charm. Thanks for the tips guys!
Old Mar 13, 2011 | 01:43 PM
jasonb's Avatar
This is the best parts cleaner I have ever used it's soooo awesome u spray and then it will dissolve the oil grease and grime then it really just evaporates !
I used this on my fork tubes to clean the inside cleaned everything No more oil or any kind of residue...!!! There is a warning about not using on rubber...
It's 3.99 for a bottle! great stuff!!
3rian
Aug 13, 2012 06:56 PM
kenenfuego
Nov 8, 2010 12:07 PM
nitrodude
F2 For Sale / Trade / Wanted
Jun 22, 2010 08:55 PM
shoortbuss
Oct 13, 2008 03:31 AM
tremblemcp
Feb 20, 2007 11:18 AM
