changed CCT-L, now a noise? also, what now?
so last night I changed out my automatic stock CCTL for the manual one from APE. talk about a pain in the ***. the writeup says that he used 1/4" drive socket/ratchet tools and all i had was 3/8", but i made it work. its really hard to get a 5/8" open wrench in there to adjust it but i think i did the best i could.
SO...no CCTL noise around 5/5.5k. however, i noticed a noise similar to the CCTL noise but this time at idle (in neutral) when i rev it, and it goes away right after 1.5/2k. the difference with this noise though is that it doesn't happen with the clutch pulled in, only when out. is this just transmission/clutch noise?
i also forgot to put on the blue threadlocker i bought which probably isn't a big deal but i do want to be safe and not have messed up my bike through my own tinkering. i am considering messing with it more tonight, maybe to loosen it and start the bike to listen for the "too loose" sound so i know what i'm looking for, then tighten it back up to make it go away and then leave it.
any thoughts/input?
any thoughts/input?
If the noise goes away when you pull the clutch lever it's definately clutch or tranny related. But some noise while idling in neutral is fine and perfectly normal as the clutch basket spins around at 1300 rpms without a load. You may have just noticed it after searching for cctl noises.
The "too loose" cctl sound is clear and obvious, its not like a faint buzzing or anything but more like a loud "clunking" as your cam chain flops around wildly. tighten the cctl JUST ENOUGH so the "clunking" stops then tighten the lock nut and you're all set.
johnk16
07-08-2013 03:17 AM
supersnake83
07-05-2009 01:56 AM
