chain/swingarm clearance
Old Mar 24, 2009 | 06:37 AM
dannutz's Avatar
Default chain/swingarm clearance
Hello everybody...
I crashed my bike a couple of weeks ago and I'm currently taking it apart...
I've come across something that doesn't look quite right and I wanted to ask your opinions about this. It looks like the clearance between the upper part of the chain and the swingarm is very small, if any. It certainly looks like the chain is touching the swingarm. Is this normal? Does the chain rise that much when tension is applied?
Thanks guys!
Old Mar 24, 2009 | 08:34 AM
redzintimidator's Avatar
yes it should touch your swingarm a little bit...at least the plastic slider that is on top of it...not metal on metal though. you can check your chain tension by picking the back tire up, spinning it to even out the slack in the chain. pick up on the bottom chain, it should only move about 20mm
Old Mar 30, 2009 | 12:52 PM
dannutz's Avatar
ah thanks mate i thought my swingarm was bent or smth... that's a great load off my chest.
cheers!
Old Mar 30, 2009 | 03:35 PM
Aken's Avatar
July 2008 ROTM
When you're not on the bike, the chain will rest on top of the swing arm. That's why there's that piece of plastic there, it helps the chain glide along.
When you're on the bike and the suspension moves, the chain moves up and off the swing arm.
romoses4
Oct 23, 2013 11:32 PM
ben_cbr
Dec 30, 2008 03:37 AM
VTcbr
Dec 20, 2008 09:25 PM
SpecR
Apr 9, 2008 09:30 PM
