Chain and Sprocket Suggestions
Old Aug 2, 2013 | 01:35 PM
Nos325's Avatar
Default Chain and Sprocket Suggestions
I would like to do a swap this winter and I was wondering what a good setup would be. I'm looking more for acceleration because there's not many places around to really get topped out. Thanks for any input.
Old Aug 2, 2013 | 02:20 PM
sickcbr1k's Avatar
I've always used 2 up in the rear, 1 down in the front...
Old Aug 2, 2013 | 03:05 PM
Nos325's Avatar
Is that with a different chain or stock?
Old Aug 2, 2013 | 03:12 PM
CorruptFile's Avatar
June 2013 ROTM
You can keep the stock chain with that config,
Old Aug 2, 2013 | 04:30 PM
Dr.Boost's Avatar
keep in mind, you will need a speedo healer when changing the sprocket set up
Old Aug 2, 2013 | 04:39 PM
Nos325's Avatar
what are some good brands?
Old Aug 2, 2013 | 10:35 PM
Aken's Avatar
July 2008 ROTM
You need to make sure your chain and sprockets are the same pitch. 525 is a typical stock size. A common size for aftermarket kits is 520. Either is fine -- you wouldn't notice the weight savings advantages on a street bike.
Typically chains and sprockets are swapped at the same time, unless you do something crazy and wear one out prematurely from the other.
I've run Driven sprockets and RK chains. I've heard EK chains are good, too, depending on which ones (some of the cheaper colored ones I'd stay away from). I know Vortex makes sprockets as well.
Old Aug 3, 2013 | 12:40 AM
Nos325's Avatar
Alright, thanks everyone for the input
maclark014
Mar 27, 2012 12:28 AM
stuck
Feb 28, 2011 09:49 AM
billetproof97
Feb 13, 2011 11:15 PM
nightfox
Feb 27, 2009 01:34 PM
