cam tensioner installation
Old 09-10-2006, 11:54 PM
Funnyguy's Avatar
Default cam tensioner installation
Hi guys
How hard is it to install the cam tensioner? I'm looking to buy an ape one but not sure how hard it is to install it.. thanks
Old 09-11-2006, 01:20 AM
spdrmns's Avatar
Default RE: cam tensioner installation
same here!
Old 09-11-2006, 01:30 AM
should be pretty easy with the right tools 1/4" extensions with an angle driver attachment.
Old 09-11-2006, 02:40 AM
Check it out brother: http://cbrworld.net/forums/thread/85183.aspx
Enjoy
Old 09-11-2006, 05:38 AM
the honda manual that all honda techs use says that u have to take off the tank, air box and throttle bodies. which isnt bad. it is a bitch to get at without doing that
Old 09-11-2006, 08:39 AM
Funnyguy's Avatar
I'll try it this weekend.. thanks for the replies guys
Old 09-11-2006, 09:27 AM
no need for this hassle. I replaced mine with manual APE one.
All you need is a simple 1$ allen L key, a piece of wood and a hammer. Just hook the shorter arm of the allen key to the bolt and apply the piece of wood to the other arm of the key and hit it with the hammer. Once the screw unscrews a bit you just turn it over with your hand. I have a flexi drive to remove difficult bolts but i didnt need it at all.
Old 09-11-2006, 11:45 AM
You will probably cuss it at least once, but a 1/4 socket, flex drive, and allen bits will get it.
No need to remove the airbox, and I just lifted and supported the tank.
foxens
05-13-2012 11:29 PM
bikeman11122
04-11-2011 11:01 AM
MARCD1
10-17-2010 12:55 PM
Blue Fox
02-11-2007 06:48 AM
CBR BoyRacer
05-15-2006 04:52 PM
Quick Reply: cam tensioner installation
