Brake lights stop working
Old 04-02-2014, 12:45 PM
icedmind's Avatar
Default Brake lights stop working
As the title for some reason my brake lights stopped working
It works before hand and all I did today was take the battery out and put it on my dirt bike to start it and put it back.
The brake light switch are both working fine with the distant click noise, and i pull the bulb out and both of them looks good to me.
It just strange that both of the bulb gone at the same time and none of the brake light is working(tail light works fine)
Any ideas?
Thanks
Kit
Old 04-02-2014, 03:42 PM
icedmind's Avatar
I have also put a new bulb in and still nothing
Old 04-02-2014, 04:12 PM
74demon's Avatar
Did you check the turn/brake fuse?
Old 04-04-2014, 12:02 PM
icedmind's Avatar
yh checked them as well
so after checking all the wiring and stuff, turned out for some reason the front brake light switch got corroded and isn't making good enough contact, rebuild it and the front works now, not sure whats going on with the rear
Old 04-04-2014, 12:12 PM
74demon's Avatar
Is the spring pulling the plunger on the rear switch? It only takes a little dirt to overload the spring. Give it a pull and a wipe with WD and watch it work, maybe.
Old 04-04-2014, 01:21 PM
icedmind's Avatar
I have changed to the banjo pressure type because my rear set did't allow the stock ones to be fitted, I think its time for a new one of that
It just wired how both of them gone at the same time
bringit609
04-20-2010 07:08 PM
LaughingMan600F4i
11-28-2008 05:12 PM
mpm600rr
09-18-2008 12:10 PM
teamdfg
12-23-2006 12:30 PM
Mn_93f2
06-29-2006 01:07 PM
Quick Reply: Brake lights stop working
