Brake lights stop working
As the title for some reason my brake lights stopped working
It works before hand and all I did today was take the battery out and put it on my dirt bike to start it and put it back. The brake light switch are both working fine with the distant click noise, and i pull the bulb out and both of them looks good to me. It just strange that both of the bulb gone at the same time and none of the brake light is working(tail light works fine) Any ideas? Thanks Kit |
I have also put a new bulb in and still nothing
Did you check the turn/brake fuse?
yh checked them as well
so after checking all the wiring and stuff, turned out for some reason the front brake light switch got corroded and isn't making good enough contact, rebuild it and the front works now, not sure whats going on with the rear |
Is the spring pulling the plunger on the rear switch? It only takes a little dirt to overload the spring. Give it a pull and a wipe with WD and watch it work, maybe. :D
Originally Posted by 74demon
(Post 1269695)
It just wired how both of them gone at the same time:icon_frown: |
