battery keeps dying then works fine again
Old Jan 2, 2009 | 10:10 AM
volcomrr's Avatar
Default RE: battery keeps dying then works fine again
ya, my bike does the exact same thing ao.... I can ride for a while, turn it off and it wont start back up, but if it sits for maybe an hour it starts up like a champ.... never have figured out what is wrong with it, and also have tried new battery, didn't fix the problem.
Old Jan 2, 2009 | 10:22 AM
redzintimidator's Avatar
ORIGINAL: fishfryer527
My next guess is the starter.
When hot, the inernal resistance rises and then won't start. Does anyone think that trying to cool the starter with a water hose after a ride would screw anything up? I am not sure if a bike starter is different than a car starter, in a car the shaft/bendixy/thing can get bent and when hot expand enough to where it binds and don't slide out.
just what i was about to suggest fish. Either starter or starter relay having more resistance because they are hot.
Old Jan 2, 2009 | 10:40 AM
thrasher572's Avatar
The starter and starter relay are only in the circuit during starts. Check the ground side of the starter circuit, including the case where it mounts. Corrosion between the starter body and the block is the most often overlooked area.
Old Jan 2, 2009 | 05:20 PM
agent orange's Avatar
sweet.. thanks guys... I'm gonna try that this weekend.. ill let you know how it goes.. i really hope that's the problem.. it really sucks not being able to ride.. especially living in so cal where it doesn't rain that much..
Old Jan 4, 2009 | 11:14 PM
well guys .. no such luck.. no corrosion on the starter terminals and i dont see any loose ground or frayed wires. dam this sucks!!
Old Jan 14, 2009 | 08:08 PM
ok guys i think i found something.. one of the bolts that mounts the starter is way loose.. almost falling out loose.. does anyone think thats what could be causing my problem?
Old Jan 21, 2009 | 04:35 PM
well guys one more thing its not.. I replaced the starter and still the same thing.. so next is the starter relay.. I'll let you guys know how it works out once it gets here and i get it on the bike.
Checkers10160
Sep 24, 2011 03:58 AM
Dragondima
Aug 5, 2011 06:13 PM
lovemy-cbr
Aug 20, 2009 09:31 PM
HondaRocks
Sep 12, 2008 04:13 AM
F4iMane
Sep 5, 2008 10:08 AM
