Any way of securing the choke?
Old Feb 14, 2007 | 04:00 AM
ddaren's Avatar
Default Any way of securing the choke?
Usually, my idle runs at about 1500 RPM.
After I left school, and came to a stop about 8 minutes later, I noticed my idle going around 1000 and going below. I noticed the sound at first. Then my bike kept dying. I was like, "WTF!!!"
Then when I pulled over, my first guess was someone changed the choke... and yeah, I was right.
Is there any way of hiding it? or securing it some how?
I'll probably hide behind the bushes with a bat tomorrow.
Old Feb 14, 2007 | 05:20 AM
Draconius's Avatar
Default RE: Any way of securing the choke?
There is no choke on an f4i. Do you mean the Idle adjustment?
Old Feb 14, 2007 | 07:26 AM
ddaren's Avatar
ORIGINAL: Draconius
lol... I guess that's what it's called. I'm still a noob. In the MSF course... the nighthawk's idle adjustment was a choke. iono... that's what the instructors called it.
Old Feb 14, 2007 | 11:00 AM
speedra500's Avatar
our bikes have an auto coolant choke, the adjustment you are talking about is an idle speed adjustment
Old Feb 14, 2007 | 11:02 AM
speedra500's Avatar
oh yea, i forgot to answer the question...you can pop it off of the little plastic holder and move it behind the fairing if you want
Old Feb 14, 2007 | 02:20 PM
method's Avatar
where is the idle adjustement located on the F4i's? on my old F2, it's this little **** on the left side...but I haven't had to use it on the F4i.
Old Feb 14, 2007 | 07:03 PM
Jaybird180's Avatar
That's where it is. You only need to adjust it once. Set at 13-1400, if memory serves correctly.
Old Feb 15, 2007 | 02:53 PM
alekinci's Avatar
fuel injection bike dont usually have a choke but the idle adjustor has a metalic pin on the plastic cap so it will not be easily moved. also i recomment to everyone that their idle speed should be more than 1500 rpm, at this speed the alternator will be always charging the battery.
Old Feb 16, 2007 | 05:45 AM
Draconius's Avatar
ORIGINAL: alekinci
And you will be using more fuel. The manual says 1300RPM's. That is what mine sits at.
mxride808
Sep 6, 2009 10:19 AM
The__Rider
Aug 13, 2009 08:48 PM
Cole
Apr 1, 2008 08:01 PM
cbrclan
Apr 29, 2006 02:43 AM
rba007
Jan 23, 2006 12:44 PM
