Aftermarket Rotors?
Old 02-14-2012, 11:46 PM
City Bike Racing's Avatar
June 2012 Ride of the Month
Default Aftermarket Rotors?
Looking for your input on these ebay rotors.
Quality? or to good of pricing to be true?
Old 02-15-2012, 04:54 AM
DonnyBrago's Avatar
Warp happy Chinese crap, avoid.
Old 02-15-2012, 11:04 AM
nickp123's Avatar
^thats what id say too, Either way avoid them but....isnt the point of wave rotors so they dont warp? I wouldnt be willing to risk my front brakes on cheap chinese parts to find out. I think id be more worried about those rivets or whatever holding the rotor to the inner part breaking or tearing or something and having the rotor separate.
Old 02-15-2012, 12:36 PM
madman's Avatar
I have heard that some of those Chinese rotors are actually not bad at all. Personally there is absolutely no way I'm paying over $500 for a set of rotors. I remember I had a buddy who raced grand-am who used to take me me to trackdays (cars) and most of the guys said they ordered the cheapest rotors ($20/set) and just replaced them more often.
Anyway back to the warpage thing. IT IS EXTREMELY RARE to warp a rotor. The vast majority of the time, there is brake pad material stuck to the rotor which causes the inconsistencies in thickness or the carrier itself may be bent/damaged. Frankly I wouldn't mind giving these rotors a shot if you're looking for a cosmetic upgrade, but frankly, if you're just looking for better feel, a new master, ss lines, and better pads would be better in just about every way.
Old 02-15-2012, 03:00 PM
Yeah I'm not sure I want to risk my well being and ability to stop to save a couple bucks.
it'd be mostly cosmetic. I already have ss lines and decent pads. I've going to do a 954 master cylinder switch when I installed the ss lines but couldn't find one at a decent price at the time.
Old 02-15-2012, 03:56 PM
nickp123's Avatar
Yeah theyre way too critical a component to risk. Too bad rotors werent $200 or so for a set, instead of each. Itd be much easier to stomach. You could always get yourself some ebc xc wave rotors for like 1-200 cheaper than galfer? I might do that myself actually.
Old 02-15-2012, 05:09 PM
DonnyBrago's Avatar
You mean DTV, not just brake pad accumulation also wear on the disc, more an issue on cars than bikes with semi floating discs ime. They certainly do warp though, visible runout with even thickness (measured with a micrometer) is warping not DTV. I check every suspected warped disc for both runout and even thickness, I have yet to come across one with significant DTV.
One thing that can happen quite often with aluminum cast wheels is that corrosion forms behind the bolt holes, pushing the centre of the disc out and making it runout. Take the disc off and check for corrosion, remove any that you find. Also check that the rivets holding the disc outer to the inner spin freely - simplest way is to put an M12 nut and bolt through, tighten it up then use a spanner on the head to turn spin the rivets, use some brake cleaner if they are sticky and work them back and forth.
In the event that they ARE warped, chinese discs are ****ing ****, you might get lucky and not warp them quickly but that tends to be the exception rather than the rule.
Oem are your best bet, have a look at a breakers/eGay and buy some second hand if you can't afford new, if they are warped send them back and try another set.
Wavy discs look gay and offer no benefit on a road bike.
Old 02-15-2012, 10:09 PM
boredandstroked's Avatar
No name unknown quality crap does not belong anywhere near a motorcycle capable of traveling 160mph.
Old 02-16-2012, 01:47 AM
96shox's Avatar
Absolutely, for a car, use the cheapest rotors available. They are just cast iron to a specific mold, there really is no performance difference, this is race tested.
As for a motorcycle, I dont know, they look a little more complicated with the rivets
DBEAU
09-06-2014 02:52 PM
siCk f 4 i
F4i - Wanted
07-25-2011 04:26 AM
radvoem
09-11-2008 06:55 PM
Ace_f4i
03-30-2008 09:22 AM
Big Gaz
02-19-2008 11:15 AM
Quick Reply: Aftermarket Rotors?
