After replacing cylinder head, bike won't start - F4i
Old Sep 30, 2010 | 03:27 PM
speedyf4i's Avatar
I believe the 3 hoses are the coolant overflow, fuel tank vent, fuel overflow hoses
Old Sep 30, 2010 | 11:31 PM
zellster's Avatar
Update:
Okay guys I went ahead and checked the timing of the cams / crank, and here are some pictures. From what I can see it looks very close to being correct. However, I would say that the sprockets are off from each other by 1 maybe 2 teeth. You can also tell from the way the sprocket bolts aren't perfectly symmetric. Even still, does this look like it would cause the bike not to start like I mentioned in my first post?
(the pictures were too big to embed)
http://img839.imageshack.us/f/img20100930205054.jpg/
http://img844.imageshack.us/f/img20100930204754.jpg/
http://img22.imageshack.us/f/img201009302049212.jpg/
http://img827.imageshack.us/f/img20100930204936.jpg/
Also, I noticed when turning the crank, that it takes two full revolutions at the TDC mark, for the cam sprockets to line up with the "in" and "ex" as shown. I'm assuming this is normal?
Old Oct 1, 2010 | 05:45 PM
nickp123's Avatar
well if the cams are indeed off from each other by a couple teeth when they shouldnt be and the timings off enough it can but if its off a few degrees than i dont think so. not entirey sure but i doubt it. that could easily cause idle problems though. im not sure what else to suggest right now
Old Oct 1, 2010 | 05:51 PM
joeroberts's Avatar
Having your marks off By one tooth well cause it not to Run more so If your chain is worn.
Old Oct 4, 2010 | 07:01 AM
RdRcr150's Avatar
Your exhaust cam is retared one tooth according to the pic if the crank is at TDC.
Old Oct 4, 2010 | 05:07 PM
jp_greenville13's Avatar
Sounds like these guys got the right idea. Keep us posted.
And I hate to say "I told you so" but, I told you so
Old Oct 5, 2010 | 02:12 PM
zellster's Avatar
Default compression sound?
Yeah I am thinking it's a timing problem. When I turn the crank for TDC, I hear a compression noise. Would this be the result of improper cam timing? When I get home today I'm going to redo the timing to try to get it perfect.
Old Oct 7, 2010 | 02:17 AM
zellster's Avatar
PROBLEM SOLVED!
Just wanted to let you guys know I redid the timing on the camshafts, and the bike works perfectly! It's incredible that having the timing off by just 1 tooth will cause the bike not to work at all.
I had made about 4 threads on here throughout the process. And I just wanted to thank everyone for helping me out. The community here is extremely knowledgeable a friendly. Thanks again guys!
Old Oct 7, 2010 | 08:49 AM
redzintimidator's Avatar
awesome, looks like i chimed in too late! It looked like your crank was turned 1 tooth too far clockwise, but your cams were alligned properly. When i chnged my cam chain i first put intake cam in 1 tooth off and it BARELY ran so this sounded kinda similar.
Glad to see its fixed, now go ride!
deeksmooth
Aug 11, 2020 03:22 PM
y2k600f4
Aug 31, 2013 06:08 AM
Avi
Apr 10, 2011 11:20 PM
Triax
Jul 11, 2009 12:39 AM
