After replacing cylinder head, bike won't start - F4i
Well after weeks of ripping out the engine, and getting a spark plug hole time-cert, apparently I did something wrong putting it all back together.
So the bike primes perfectly fine, and all the electrical stuff seems to be good. But it won't start unless I give it full throttle; and when it fires it's doesn't sound right, and it's a very low idle. And when I close the throttle, it dies. Also, when it does start, I smell almost a slight burning smell (it might just be excess fuel dripping out since I'm at full throttle). Any ideas on what could be the problem? Does it sound like a timing issue, because that's what I'm thinking. I aligned everything according to the service manual, with TDC at the crank and the cam markings. I suppose it's possible it moved a bit. Could it be something with the spark plugs? Or a hose that didn't get connected? I really don't know where to start. Any help would be greatly appreciated. |
It sounds like a timing/spark plug issue. You sure the ignition coils are in the right cylinders and theyre firing in the right order?
You mean the rubber ignition coils? Or are you talking about the electrical connectors to them? I'm pretty sure they are in the right order, I can recheck.
yeah the wires going to the coils that deliver the spark. If those aren't on in the right order the cylinders wont fire in the right order. Is there any unusual shaking or vibrating when the bikes in gear?
Originally Posted by nickp123
(Post 972109)
From what I described in my initial post, does it sound like the timing could be messed up? The bike won't start at all, unless I give it FULL throttle, and hold it. The engine will turn on, and be at a very low RPM, then if I let off the throttle at all, it dies instantly. And the engine doesn't sound quite right, either. Any other ideas on what could be the problem, before I check the timing? Thanks for the help! |
Throttle position sensor? Would affect the engine timing and fuel mix which could cause symptoms like that I think
definately check the timing. the tps would throw a code but it shouldnt prevent you from starting the bike like that. If the timings off or it is a misfire could not fire or start until theres a lot of gas in there to ignite like when you give it full throttle, could also explain why it smells like its running rich.
check your vaccum lines too. a rough or low idle might mean its not getting enough air and then the fuel wouldnt be completely burned either resulting in that smell. but all could relate to timing or tps sensor once its running like kuroshio said actually
(Post 972253)
Also I do have a power commander installed. Should I try hooking up the stock connectors? Thanks for the help :) |
if my bike wasnt in a different state id be glad to go look and see but maybe someone else could. if its a drain than i doubt it but if its something else and something isn't recirculating like it should be than there you go. Stock connectors couldnt hurt but doesnt the pc automatically adjust the a/f ratio or does it only adjust it to the map that you have running? if so maybe you need to change the map. did you do anything to the intake, exhaust, or heads that would cause a change in the a/f ratio?
