06 F4I problem
Old May 31, 2007 | 10:05 PM
gittinitup's Avatar
Default 06 F4I problem
Ok so I found an oil leak on my 06 with 4k miles on it!! It is comeing from the little weap hole under the #1 header pipe coming off the head!! you know the little 4 holes under each header pipe on the head, in case no one has notice those!! So what can cause this?
Old Jun 1, 2007 | 12:24 AM
areacode312's Avatar
Default RE: 06 F4I problem
Well the stupid answer is:
unless there is a hole in your engine block.....
you have a leaky gasket/seal.
Call up a dealer and see what they say about a replacement seal in that area or something that can vibrate loose and let oil out.
How much oil is coming out and when is it coming out?
Old Jun 1, 2007 | 09:52 AM
gittinitup's Avatar
its allready at dealler they said either head gasket, rings, or could be any other internal engine problem! They said when stuff comes out of that hole there is a big problem!!
Old Jun 1, 2007 | 10:37 AM
slip_'s Avatar
Yeah I can imagine, oil coming out of your engine is never good lol..
Old Jun 2, 2007 | 05:08 AM
F4iT's Avatar
probaly the head gasket i personalyhave instaled 3 engines in f4i's and see no such hole the only hole thats around is the coolant block drain the dealer more than likely wants you to spend a lot of money with them my suggestion is go out and buy a clymer manual its only 20.00 best investment
Old Jun 2, 2007 | 04:34 PM
gittinitup's Avatar
no there are 4 small holes on the head, one below each exhaust port going into header
kwood
Jun 1, 2020 09:53 AM
hatchtegman
Sep 1, 2010 03:15 PM
vietladin
Dec 25, 2007 09:48 AM
dewthedoo05
Sep 4, 2007 09:32 PM
Trips
Nov 26, 2006 01:45 AM
