valves
Old May 16, 2010 | 02:00 PM
fusionf5's Avatar
Default valves
Just wondering before i go and rip it apart. How often do the valves need to be replaced around 16k. The book says to check them at 16k and im a little over that. Im just wondering because for cars it says to change something at a certain mileage and a ton of people never do. I mean i never changed my antifreeze on my jeep and it went to 300k miles. So just wondering if its just a check or does it really need to be changed?
Old May 16, 2010 | 05:10 PM
nitrodude's Avatar
You dont replace valves at 16k, You check the clearances.
Old May 16, 2010 | 05:12 PM
nitrodude's Avatar
Heres a good tutorial to checking/adjusting your valves
http://www.musclecross.com/forum/viewtopic.php?id=97
Old May 16, 2010 | 07:50 PM
Sand.Man's Avatar
Honda valves are known to almost never go out of spec, go ahead and check them to be safe but chances are you won't have to swap any shims.
Old May 16, 2010 | 09:07 PM
fusionf5's Avatar
yeah i know it says check them, i was just seeing if people actually replace shims at that time..
thanks a lot though for the help
Old May 16, 2010 | 10:21 PM
halffast1g's Avatar
my mechanic said f2 valves are known to come out of adjustment. . . . lol
Old May 16, 2010 | 11:31 PM
fusionf5's Avatar
lol i deal and work with techs (for cars) and they will always tell you things like that.. just trying to sell you something you don't need
Old May 16, 2010 | 11:37 PM
Kuroshio's Avatar
If you're doing it yourself, checking the valve clearance costs nothing. If its not done and they do need adjustment, you can end up bending a valve and causing excessive wear. If the clearances do need adjustment, the cost of a shim kit is more than worth it.
It's not some bullchit mechanic ploy. To be 100% honest, most mechanics don't wanna do the valves on the older bikes
CorruptFile
Jul 19, 2019 12:57 PM
camaroloverx4
Sep 17, 2012 06:56 PM
Kuroshio
Sep 29, 2009 06:43 PM
lonewolfcbr
May 7, 2008 10:33 PM
929BEATSTI
Apr 24, 2008 04:38 AM
