Throttle sticks!
Old Aug 7, 2012 | 11:58 PM
magnumRT's Avatar
Default Throttle sticks!
my throttle sticks unless i manually decrease it. im assuming its the cable? thanks
Old Aug 8, 2012 | 01:18 AM
RedBaron's Avatar
Yes, there are 2 cables for the throttle one pushes and the other pulls so it could be either one or both.. they might just need some lube.
Old Aug 8, 2012 | 10:21 AM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
It could be something very simple, like the grip having slipped a little, and is sticking against the bar end - if you haven't already, make sure your grip isn't binding at the bar end or at the throttle housing/switch assembly.
The cables are your most likely culprit - you'll have to do a lot of work to properly lube the cables (remove tank, airbox, disconnect cables at both ends...) but if you do a good job, using the old "bag full of lube" method, they'll be good to go for quite some time - there's also tools out there designed to clamp around one end of the cable, and seal it up, allowing you to use the "straw" from the aerosol can to inject the lube under pressure, until you see it coming out the other end.
Lastly, if you have done any carb work, or work of any sort that required you to re-position these cables at all, you might just make sure they're routed properly...it's surprising how little you can move a cable, and end up with some binding.
Old Aug 8, 2012 | 03:48 PM
adrenalnjunky's Avatar
Seconded. Had to replace my throttle cables, and I found binding until I routed one over a portion of the frame where they had been going under.
Old Aug 9, 2012 | 07:12 AM
JankCibberf2's Avatar
Wait, their suppose to go under the frame?? mine go above the frame at that stupid upside down v where the frame connects to the triple tree. I just decided to deal with the sticky throttle lol
Old Aug 9, 2012 | 08:05 AM
JNSRacing's Avatar
Over the frame, under that metal cable guide is the correct routing, but it IS tight, if it's not done perfectly... it takes some tinkering.
filthydanger
Feb 24, 2011 01:04 AM
N8 Dawg
May 7, 2009 07:04 PM
skatalact
Mar 15, 2009 07:59 PM
MrBomb
Dec 13, 2008 12:32 PM
mitchedwards81
Mar 13, 2007 03:38 PM
