Throttle sticks
Old Jul 18, 2006 | 09:44 PM
N8 Dawg's Avatar
Default Throttle sticks
I have a 2000 F4 and the throttle sticks. This is my first sport bike and I have to pull the throttle back it does not come back on its own. I wouldnt think that is normal for this bike? I have drove a couple cruisers and never had this problem.
Old Jul 19, 2006 | 12:11 AM
ddvs's Avatar
Default RE: Throttle sticks
Check the bar end on your throttle side, make sure its in the proper slot and then loosen or tighten until you get the response you want, if you loosen it, make sure you check the tightness or looseness at stops. Also maybe check the grips, new ones maybe? If not maybe the throttle cable is malfunctioning, just a few things to consider.
Old Jul 19, 2006 | 12:29 AM
mikey1297's Avatar
i had the same problem on a ninja i use to have untill i had to take the carbs off and clean the so maybe check the cleanness around the carbs(if ya get what im sayin)
Old Jul 19, 2006 | 03:08 PM
ddvs's Avatar
I know the 99 is carbed idk about the 00 or the 01, when was the last production carbed cbr? Also are older repsol bikes carbed?
Old Jul 19, 2006 | 08:21 PM
mikey1297's Avatar
00 is the last pro carbed not sure about repsol
Old Jul 19, 2006 | 11:54 PM
N8 Dawg's Avatar
Thabks ddvs, I loosened the bar ends and now it is fine. I also bought some new grips but I dont have them on yet. Didnt think the throttle should be sticking like that but someone told me thats how CBR's are......guess I should have asked someone that has actually rode one first.
Old Jul 20, 2006 | 06:55 AM
otisdr's Avatar
2k1 introduced fuel injection IE the F4i (injected) name
2000 was the last model year for the F series 600's to be carbed
Old Jul 21, 2006 | 09:01 AM
*PHOENIX*'s Avatar
N8 Dawg just to let you know, if any one tries to fob you off with that again no bikes throttle should ever stick.
Old Jul 21, 2006 | 04:41 PM
rydnlo99's Avatar
hey man i had this same exact prob. heres what u do... take off the rubber grip, unscrew the top half of your engine on/off switch (2 screws) then slide the white plastic part basically off the black metal bar. U kinda gotta work with it like bend it downwards for it to start slidin off. Its cuz there is some gunk between the 2 causin friction. Go down to AutoZone and get a 3dollar thing of gear grease and lube in between those 2 parts. should snap back to the closed positon better than before. Its either that or look to see if your throttle cables and kinked anywhere. Hope this helps.
Old Jul 21, 2006 | 06:55 PM
ddvs's Avatar
Who ever told you that CBR's throttle sticks is a complete hater! According to that statement to you, he is trying to say that our CBR's havn't won Supermoto and Superbike Championships multiple times, especially by the infamous Rossi. Final thoughts are he/she has NO idea what he/she is talking about. Who told you that a GSX rider? or a Harry Baldson rider?
