only turns over manually
Old Oct 4, 2011 | 05:13 PM
coldflood's Avatar
Default only turns over manually
bypassing the starter with the two terminals on the relay wont work makes a binding-squeaky sound with the gears but will rotate with breakerbar (hear like a hydraulic noise when i do this almost squirting sound). This happenend after i torqued down the stator cover... wth?
the starter gear with the case doesn't rotate either
Also broke off part of the starter boss initially too.
Please help
Old Oct 4, 2011 | 05:58 PM
buickid's Avatar
You might want to take the cover off and check things. You may have screwed something up.
Old Oct 4, 2011 | 06:00 PM
coldflood's Avatar
already did that looks normal as far as I can tell
Old Oct 5, 2011 | 07:44 AM
JankCibberf2's Avatar
Over torqued it ehy? Shoulda done hammer time
Old Oct 5, 2011 | 08:40 AM
coldflood's Avatar
I did, used a rubber mallet but couldn't get all the holes to line up bent cover? Anyways the gear should still rotate shouldn't it what do i have to do to fix this?
Old Oct 6, 2011 | 06:57 PM
coldflood's Avatar
update:
So I started hitting the starter gear with a flathead and rubber mallet to see if it would turn didn't spend a whole lot of time but after i did that I noticed i could get the gear to move laterally which was odd? Anyways a couples times i got it to turn but then it would jam right up again. Any thoughts or ideas as to what this may be?
rons93rr
Mar 17, 2008 08:12 PM
voodoochyl
Jul 27, 2007 08:15 AM
FordFrenzy97
Jul 21, 2007 04:15 PM
9 fiddy fo
Sep 23, 2006 08:43 AM
03954guy
May 31, 2006 10:53 AM
