manually turning the motor
Old Mar 16, 2008 | 06:43 PM
rons93rr's Avatar
Default manually turning the motor
hi, i have a problem starting my bike. it is a 93 cbr 900rri bought this bike in april of 07, it was crashed and needed a lot of work. well i finally got 97 percent of the parts to complete my project. when i try to start it the starter fires but the motor does not start it does not even crank.. is there a way to manually turn the crank to make sure that the motor is not locked up (seized)???
thanks, ron
Old Mar 16, 2008 | 08:24 PM
elmer's Avatar
Default RE: manually turning the motor
If you look on the right side of your bike and just forward of the clutch cover there should be a circular cover with what I think is a 14mm bolt head on it. Use a socket to take that off and then behind there should be a bolt head attached to the crank that you can put a socket on and manually turn the engine over with.
Old Mar 16, 2008 | 08:33 PM
Ty's Avatar
Ty
If it's been sitting a while, you may want to take out the plugs and put a little bit ofliquid wrench in it overnight. Might free it up if the rings are seized. On a car you can just turn the crank by hand with a socket on the bottom crank pulley. Not sure if you can do that on a bike, but if you do, take the plugs out first.
Old Mar 16, 2008 | 10:30 PM
rons93rr's Avatar
hey,
thanks for the info. i will definatly try to find the bolt to turn it over. i will also try to put some liquid wrench in, i know that the bike was sitting for quite awhile.
Old Mar 16, 2008 | 11:54 PM
elmer's Avatar
Ty, thats what I'm referring to on the bike, its a bolt head that turns the crank instead of a pully. You can turn it over without taking out the plugs but it will be a lot easier to turn over with them out. If you suspect the engine is siezed, Ty's advice is good.
Here's a pic of what I'm talking about. Remove the cover the arrow is pointing to. then turn the bolt head underneath with a socket to turn the crank.
[IMG]local://upfiles/12799/FAE41C928D0746B68661680F8FDF6342.jpg[/IMG]
Old Mar 17, 2008 | 07:39 AM
Ty's Avatar
Ty
Cool, never tried it on a bike before, figured it had to be fairly similar. Good pic.
Ron, don't be scared to put some weight behind it ifat first itwon't budge.
Old Mar 17, 2008 | 08:12 PM
rons93rr's Avatar
WOW! thats great thanks alot for the picture it helps alot. and don't worry about me putting my weight into it ,i'm not known for my finesse i'm a bit of a bull. worst case sinareo what do you think it would cost to have the motor re-built? any idea? thanks again, ron
foxens
Oct 20, 2013 05:09 PM
ekelman
May 6, 2012 10:12 PM
yumoncbr
Feb 1, 2012 10:56 PM
coldflood
F2 Tech
Oct 6, 2011 06:57 PM
xRej3cTx
Dec 25, 2007 11:15 PM
