No power! I need help PLEASE!!!
Old 04-26-2012 | 09:39 AM
underground-mpyre's Avatar
Try putting the bike in neutral with the kickstand up and see if it starts. Crossing two live wires could be a short withg anything connecting to the harness.
Old 05-14-2012 | 02:54 PM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
Leaking cable?!?
When you say "still no power", what exactly do you mean? Is there not enough electrical power to run your lights, etc., or do you mean the engine is lacking power? or both?
Old 05-15-2012 | 03:53 AM
Look in your Honda service manual, in there you will find the fields what your fields should be with a volt-tester staring with the stator. More than likely, you RR(rectifier/regulator) is not making the electrical loop and draining your battery or your stator isn't charging your battery. Doesn't matter if your lights come on, but if there is no click when starting your battery is actually running the show.
coolbluedab
02-07-2014 07:13 PM
romanboy
01-19-2013 12:53 AM
__Z__
07-14-2010 10:00 AM
Karmakazi
09-29-2009 09:58 AM
Certified Ryder
11-12-2007 10:13 PM
Quick Reply: No power! I need help PLEASE!!!
