New Spark Gernerator
Old Sep 16, 2013 | 09:11 PM
GPiper's Avatar
Default New Spark Gernerator
Just got a new spark generator and I found a problem. My bike had the spark generator hard wired to the ICU and the wires are all the same color. The new one has solid yellow wires, all three the same. All three on my bike are yellow with silver stripes. What is the best way to figure out which one goes to which one. Surely there has to be some order or is there?
Attached Thumbnails New Spark Gernerator-new-end.jpg   New Spark Gernerator-wires-bike.jpg
Old Sep 16, 2013 | 10:37 PM
gpfan1's Avatar
According to my f2 manual, the yellow wires are labeled 1,2,and 3. On the schematic it has the perspective of looking down on the connector from the alternator and the connector to the r/r. from left to right on the connector from the alternator, the yellow wire on the far left pin goes to the yellow wire pin closest to the center of the r/r. The next wire from the alternator connector goes to the middle yellow wire connector on the r/r end. The last and right hand wire from the alt. goes to the outside, leftmost connector on the r/r. Pag 19-1 in the Honda manual. Here's the diagram for a 91 f2.
Old Sep 17, 2013 | 06:16 AM
gtcole's Avatar
Welcome Crew
As far as I know, the wires are interchangeable, don't quote me on that. However, on my 94 they were disconnected and then hardwired together with no regard to order. Works as its suppose to. Check the RR sticky, I believe that's where it was mentioned in detail.
Old Sep 17, 2013 | 09:26 AM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
Your three stator wires are completely interchangeable - you will be fine no matter which you connect to which.
baseballkid
Oct 4, 2012 07:48 AM
cncquinn
May 21, 2011 04:55 PM
jaredaamy
Jan 1, 2009 10:51 PM
Bazman
Nov 23, 2008 01:13 AM
w4kr
Jun 11, 2007 04:44 PM
